Transforming engineering content for AI readiness
Learn how trusted asset data intelligence connects engineering content and enterprise systems to build an AI-ready information foundation.
Engineering organizations manage enormous volumes of information. P&IDs, CAD drawings, data sheets, maintenance records, vendor documentation, inspection reports, and operating procedures contain the knowledge needed to operate, maintain, and improve critical assets.
Before organizations can realize the promise of AI, they must ensure that engineering information is discoverable, validated, connected, and trusted.
Yet much of this engineering information is scattered across repositories. Asset tags may not match the organization’s master asset database, while drawings and documents often lack the consistent, high-quality metadata needed to make content easy to find, trust, and use. As organizations scale artificial intelligence (AI), this fragmented information landscape becomes a significant challenge.
Engineering information becomes AI-ready when organizations extract and validate asset data, connect documents to authoritative asset records, and make those relationships consistently discoverable. When engineers identify discrepancies between physical assets and the documentation that describes them, streamlined content management processes help route, review, update, approve, and govern the necessary changes. AI systems can deliver more trusted answers when they have access to accurate, complete, contextualized, and continuously maintained information.
Cad-Capture’s Asset Data Intelligence (ADI), OpenText™ Content Management (Extended ECM) for Engineering, and OpenText™ Documentum™ Content Management for Engineering provide a powerful foundation for AI readiness by validating asset data, connecting engineering content to authoritative records, and governing engineering content throughout its lifecycle.
How an asset-centric digital thread supports AI
One of the greatest challenges facing engineering and operations teams is maintaining a consistent relationship between physical assets and the information that describes them. Asset tags are often embedded within CAD drawings, PDFs, and scanned documents. Over time, naming standards evolve, drawings become outdated, and discrepancies emerge between engineering documents and enterprise master data.
Cad-Capture’s Asset Data Intelligence addresses this challenge by automatically extracting asset tags from native CAD files and PDF documents. It then validates those tags against authoritative enterprise sources, helping organizations identify inconsistencies, missing records, duplicate assets, and naming conflicts.
Teams can flag and correct asset tags that do not match the master asset list before those discrepancies create downstream problems for engineering, maintenance, or AI initiatives.
This validation process creates a trusted, asset-centric digital thread that connects engineering content with operational records. Organizations can associate drawings, maintenance histories, procedures, data sheets, inspections, and vendor information with the correct asset. Instead of searching several systems for related information, teams gain a unified view of each asset and its supporting documentation.
How intelligent HotSpots connect drawings and records
Engineering drawings contain some of an organization’s most important information, yet they can be difficult to navigate. Finding related records often requires workers to switch manually between systems and repositories. This consumes time and increases the risk that they will miss critical information.
ADI transforms this experience through intelligent HotSpots. After ADI extracts and validates asset tags, drawings can become interactive gateways to enterprise information. Engineers, maintenance personnel, and operations staff can select an asset directly from a drawing and navigate to related records, documentation, maintenance history, procedures, or operational data.
This capability improves information accessibility while reducing the effort required to locate supporting content. Instead of searching enterprise content management, enterprise asset management, and enterprise resource planning systems independently, users can access relevant information directly from the engineering drawing where work often begins.
HotSpots also reinforce the relationships between engineering content and operational systems. These relationships make it easier to understand how assets, documents, and records connect. They also provide essential context for future AI applications. When AI systems can use the same validated relationships available to workers, they gain a more complete view of the operational environment.
How validated engineering data improves AI context
AI is only as trustworthy as the information behind it. In engineering environments, the challenge often begins with poor data quality. Asset tags may be missing, duplicated, inconsistent, or out of sync with enterprise master data. If an AI system cannot distinguish between an asset reference in a drawing and the authoritative asset record, it may produce inaccurate answers.
Cad-Capture’s Asset Data Intelligence addresses this challenge through AssetXtractor, which extracts asset tags from native CAD files and PDFs, then validates them against enterprise systems to identify discrepancies, missing records, and incorrect references.
CaptureFlow complements this process by extracting title-block information and engineering metadata. This improves classification, searchability, and governance across engineering content repositories. Together, these capabilities create cleaner and more reliable engineering data before it reaches AI systems.
The result is a stronger foundation for AI readiness. Instead of reasoning across disconnected documents and inconsistent asset references, AI can access validated engineering content linked to trusted asset records. This improves accuracy, traceability, and confidence in each response.
Key takeaways
  • Validated asset tags connect engineering documents to authoritative asset records.
  • Interactive drawings help users navigate directly to related enterprise information.
  • Connected, contextualized engineering content gives AI a more reliable information foundation.
Prepare your engineering information for AI
Preparing engineering information for AI is not about creating more data. It is about creating trusted context.
Cad-Capture’s Asset Data Intelligence and OpenText Content Management help organizations extract, validate, correct, and connect engineering information. This gives both workers and AI systems access to the asset knowledge they need.
Explore OpenText Content Management for Engineering to learn how your organization can connect engineering information with enterprise processes and build a trusted foundation for AI-ready operations.
Phil Schwarz
Phil Schwarz is the Industry Strategist for Energy and Resources at OpenText. With two and a half decades of energy industry experience, Phil has become a trusted SME, having supported operators, EPCs, service providers, and OEMs across the entire energy value chain. Phil is an engineer by education and has an MBA, M.S. in Economics, and M.S. in Finance. He also has a Graduate Certificate in Smart Oilfield Technologies and executive certificates in AI Applications for Growth and Data Strategy. He resides in the Anchorage, Alaska area and loves to hike and enjoy the outdoors.
