The dashboard problem: how data security posture management got stuck at visibility
Why finding sensitive data is no longer enough, and how integrated controls can turn DSPM insights into measurable risk reduction.
A few years ago, we didn’t know where our sensitive data lived. This was one of the most honest sentences a CISO could say. It explained the breaches, the failed audits, and the compliance gaps that seemed to come out of nowhere. So the market built a category to answer that question. Data security posture management, or DSPM, promised something simple: scan everything, classify everything, and finally see where sensitive data sits — across cloud buckets, SaaS apps, data warehouses, and forgotten file shares.
Data security posture management must evolve from identifying sensitive-data risk to helping teams assign ownership, apply controls, and verify remediation.
It worked. DSPM tools do what they were designed to do, and they do it well. Discovery engines crawl environments that used to take manual audits months to map. Classification models tag personal data, financial records, and regulated information more consistently than manual review typically allows. Risk scoring puts a number on exposure that finally gets budget approved. For a problem that used to be invisible, DSPM made data risk visible.
But visibility was never the finish line. It was meant to be the starting point for action.
Why DSPM findings pile up faster than teams can act
Walk into almost any security operations review today. You’ll see a familiar pattern: a dashboard filled with thousands of findings. A risk score trending the wrong way. A queue of “critical” alerts that never seems to shrink.
DSPM platforms are exceptionally good at generating findings. They rarely help anyone act on them.
The volume doesn’t add up. A single discovery scan across a mid-size enterprise’s estate can surface anywhere from thousands to tens of thousands of exposed or misclassified data instances in one pass, depending on the environment. Even a well-staffed data security team can typically remediate only a portion of that volume each quarter. Teams often create and duplicate new data faster than they close old findings. The backlog doesn’t just persist. It compounds.
This is less a tooling failure than a design gap left over from an earlier stage of the category. Vendors built most DSPM products around detection first. Detection was the problem everyone could agree on and fund. Remediation stayed part of existing workflows instead: someone hands a ticket to an app owner, a request gets routed to IT, or a policy exception goes unresolved. That approach made sense when the priority was proving data risk existed. As organizations have matured, reducing that risk has become just as important as finding it. Teams increasingly expect remediation to be a built-in part of the workflow, not a handoff to someone else.
Detection without control is just better-informed anxiety
There’s a version of data security that has quietly become normal: teams that can describe their exposure in detail but can’t meaningfully change it. They know which datasets are overexposed. They know which repositories haven’t been reviewed in years. They know which cloud storage buckets are misconfigured relative to policy. Teams refresh that dashboard nightly. They review it in steering committee meetings. Then it sits there, largely unactioned.
Part of the problem is organizational. Data security findings often cross team boundaries that visibility tools never bridge. A misclassified dataset might need action from a data owner in finance, a platform engineer in IT, and a compliance reviewer — and rarely do they log into the same console or share the same sense of urgency. Part of the problem is technical, too.
Many discovery platforms stop at identifying and scoring risk. They don’t apply protective controls — masking, encryption, tokenization, redaction, access restriction — directly to the data itself. Teams often treat flagging risk and closing it as separate problems, solved by separate tools, if they’re solved at all.
The result is a widening gap between what organizations know and what they can control. In many organizations, boards ask why the risk score hasn’t moved despite a year of DSPM investment. Auditors ask why findings from the last assessment are still open. Security leaders end up explaining that visibility, however thorough, was never the same thing as remediation.
Why DSPM’s next phase has to be about control, not just discovery
What comes after DSPM visibility?
Closing the gap between finding risk and fixing it typically comes down to three things:
  1. Assign ownership — route each finding to the person or team who can actually act on it.
  2. Apply appropriate controls — mask, encrypt, restrict, or redact the data itself, not just flag it.
  3. Measure closure — track time-to-remediation the same way security teams already track time-to-detection.
The narrative is starting to shift. Some organizations getting real value from their data security platform have stopped treating discovery as the finish line. They treat it as a starting input instead. Findings get routed to the right owner automatically. Protective controls — masking or access restriction, for example — get applied where policy allows, instead of waiting on a ticket. Teams track closure the same way they’d track a vulnerability through a patching cycle, with an actual owner and an actual deadline.
That shift matters because it changes what “good” looks like. A shrinking backlog becomes as important as a comprehensive scan. Time-to-remediation gets tracked the same way time-to-detection always has.
The conversation moves from “How much sensitive data do we have exposed?” to “How much less exposed are we than we were last quarter?” That is a question dashboards alone were never built to answer.
DSPM solved the problem the industry set out to solve. The next problem, and the real challenge, is closing the gap between finding risk and fixing it. That challenge will determine whether the category reduces exposure or simply documents it more precisely.
Getting there will take more than better scanning. It will require a practical path from insight to remediation — one built around a data discovery platform that can turn findings into resolved risk, not just another line on a dashboard.
Enjoyed this piece? Subscribe to get the next one on how data security teams are closing the gap between finding risk and fixing it.
Mutaharra Mian
Mutaharra Mian is a Product Marketing Manager at OpenText focused on data security, privacy, and risk insights. She currently manages product marketing for OpenText Voltage DSP, helping organizations discover sensitive data, assess risk, and strengthen compliance initiatives. With the growing importance of data governance and protection, Mutaharra is committed to helping customers gain the visibility and intelligence they need to make informed security decisions and reduce organizational risk.
