How does AI influence treasury?
AI in treasury management can help teams turn connected financial and operational data into better forecasts, faster insights, and more informed decisions—but context and control matter.
Treasury teams have no shortage of data. Bank balances, payment activity, invoices, receivables, orders, shipments, market data, forecasts, and business-unit plans all contain information that could influence the next liquidity or cash decision.
The problem is that this information rarely arrives together.
It is distributed across banks, ERP systems, treasury management systems (TMS), payment platforms, business processes, spreadsheets, and external partners. That fragmentation makes it harder for treasury to understand not just what has happened, but what it means and what should happen next.
This is where AI in treasury management has significant potential. But getting value from AI starts with something less glamorous: connecting the information that gives AI the context to be useful. Because as we all know: AI is only as useful as the context behind it.
To get value from AI you must begin with something less glamorous: connecting the information that gives AI the context to be useful.
A bank balance tells treasury how much cash is available at a point in time. It does not necessarily explain what is about to change.
Consider a delayed shipment. On its own, it is a supply chain event. Connected to an invoice, expected receipt, cash forecast, and liquidity position, however, that delay becomes meaningful to treasury.
The same applies to a rejected payment. AI could identify or summarize the exception, but the insight becomes far more useful when treasury can connect that rejection to the underlying obligation, payment status, forecast, and expected cash position.
This is why modern treasury needs to look beyond the bank balance. Learn more in the blog, The treasury visibility crisis: Why global enterprises are rebuilding financial connectivity.
Where can AI create value in treasury?
AI can support treasury across a range of activities, particularly where teams need to interpret large volumes of information, identify patterns, investigate issues, or make decisions quickly. Near-term opportunities include:
  • Forecasting and scenario analysis: Identify patterns, compare forecasts with actuals, surface material variances, and help treasury understand changing assumptions.
  • Anomaly detection: Highlight unusual payments, cash movements, transaction patterns, or other activity that may warrant investigation.
  • Investigation assistance: Bring relevant information together, summarize an issue, and help teams understand potential causes more quickly.
  • Decision support: Provide recommendations based on connected banking, financial, and operational information.
  • Workflow support: Route issues, recommend next steps, or trigger appropriate reviews based on defined rules and context.
  • Treasury analytics: Make complex information easier to explore and interpret, helping teams uncover trends and relationships across financial and business activity.
The objective is not AI for AI’s sake. It is to give treasury better information sooner, so people can make better decisions.
From business signal to treasury action
The real opportunity emerges when AI becomes part of a connected flow from signal to context and then from decision to action and finally to outcome.
A business event provides the signal. Connected data explains what that event means. AI and analytics can help determine what deserves attention or recommend what should happen next. Treasury can then inform, investigate, approve, update, or execute an appropriate action.
For example, a material forecast variance might trigger scenario analysis and a revised recommendation. A payment rejection could launch an investigation and update liquidity expectations. A change in operating activity could give treasury earlier warning that expected cash timing is shifting. This connection between operational and financial activity is explored further in the ebook, Treasury. Managed..
More AI does not mean less control
As AI capabilities advance, there can be a temptation to jump from insight directly to autonomous execution. Treasury requires a more measured approach.
Not every event should automatically trigger an action. Some events should simply inform treasury. Others can support a recommendation or route an issue for review and approval. Autonomous execution should be reserved for trusted, bounded scenarios where the organization has sufficient data quality, authority, governance, controls, evidence, and auditability.
The appropriate level of automation depends on both the quality of the information and the materiality or significance of the decision.
That distinction is particularly important for payments, where strong validation and control remain essential. The Simplify payments. Strengthen control. guide explores how organizations can strengthen payment processes while reducing manual effort.
Build the foundation for AI-enabled treasury
The future of AI in treasury management isn’t simply about deploying more sophisticated models. It is about creating the connected foundation those models need. When banking activity, financial information, operational events, treasury workflows, and business context can work together, treasury gains the foundation to move beyond explaining what already happened.
AI can then help teams detect what is changing, understand why it matters, evaluate possible responses, and act with better context. The goal isn’t autonomous treasury. It’s better-informed treasury—with AI applied where it can improve visibility, forecasting, investigation, decision support, and ultimately business outcomes.
Ready to connect treasury to the business it supports? Talk to an expert in treasury infrastructure and operations.
Rebecca Graves
Rebecca is Senior Content Strategist at OpenText. She helps simplify complex messages and present a learning journey that makes sense so customers can quickly and easily find the information they need. Rebecca has been in the software industry for almost 20 years, specializing in storytelling, and has a degree from Queen’s University.
