Scale smart: How GitHub and OpenText unlock trusted AI for enterprise DevOps
In sectors where uptime is sacred and compliance is non-negotiable, speed alone isn’t enough. You need precision; you need audit-ready confidence; you need AI-native software…
Michael O'Rourke  profile picture
Michael O’Rourke
July 22, 20253 min read
close-up shot of laptop with complex enterprise devops processes being simplified by AI for devops
In sectors where uptime is sacred and compliance is non-negotiable, speed alone isn’t enough. You need precision; you need audit-ready confidence; you need AI-native software delivery that’s built for the realities of regulated, high-stakes enterprise DevOps.
That’s why OpenText™ DevOps Aviator now flies with a copilot—thanks to its new integration with GitHub Copilot!
This marks a major leap forward in AI for DevOps—where artificial intelligence isn’t just an assistant, but an architect of secure, compliant delivery. More than a productivity boost, the integration of OpenText DevOps Aviator and GitHub Copilot Extensions redefines what AI can achieve when it doesn’t just support developers—but intelligently orchestrates enterprise-grade software delivery from end to end.
“Organizations working in high-stakes environments need more than generic automation,” said Tal Levi-Joseph, VP of Software Engineering at OpenText. “Our partnership with GitHub brings intelligent, secure, and compliant AI assistance directly into developers’ native workflows—unlocking real productivity while reducing risk.”
DevOps re-architected for AI-native software delivery
As part of OpenText Cloud Editions (CE) 25.3, this integration brings AI for DevOps directly into the OpenText™ Core Software Delivery Platform. From initial planning through testing, deployment, and feedback loops, AI is no longer bolted on. It’s built in—tailored for the scale and complexity of enterprise DevOps.
What this unlocks:
  • Security-first pipelines with STRIDE-based threat modeling that’s AI-driven, not manual.
  • Regression-proof testing across unit, UI, and integration layers—unified and platform-aware.
  • AI-powered planning that converts features into traceable, sprint-ready tasks.
  • Smarter defect resolution that transforms fragmented issue data into prioritized fixes.
The result? Fewer handoffs, faster resolution, and traceability your auditors will love.
AI that builds, tests, secures—and delivers
Where other copilots stop at code, OpenText DevOps Aviator delivers full-lifecycle intelligence—with compliance, performance, and security engineered in.
But that’s just the start. Key innovations in CE 25.3 empower teams to:
Unify and supercharge testing
Generate JUnit tests and Selenium flows automatically. Shift from testing laggard to testing leader—without scripting debt.
Get suggestions for automated tests using Java for enterprise devops - screenshot
Shift security left
Build threat models from day one. Surface vulnerabilities before release and maintain a defensible compliance posture.
Crush defects with contextual AI
Turn bug data and team chatter into clear, actionable fixes—so developers resolve issues faster with less guesswork.
Ask AI to generate a strategy to fix defects for enterprise devops - screenshot
Plan with precision
Use AI to break down features and stories into testable tasks, improving estimation accuracy, aligning sprints, and keeping teams on track.
Turn requirements into reusable tests
Convert Gherkin-style requirements into executable behavior-driven development (BDD) scenarios. Align product, QA, and compliance from the start.
Generate Gherkin tests for user stories for enterprise devops
Built for enterprises. Tuned for trust.
Unlike generic copilots, this joint solution is purpose-built for environments where software quality, governance, and compliance are non-negotiable, enabling:
  • Audit-ready automation across every phase of software delivery.
  • Enterprise-grade traceability for every requirement, test, and defect.
  • Faster time-to-value without sacrificing security or control.
If you’re under pressure to deliver software faster—but can’t afford to compromise trust—this is your copilot for the road ahead.
Learn more about OpenText DevOps Aviator and contact us for a demo.
Michael O'Rourke avatar image
Michael O’Rourke
Michael O’Rourke is a product and marketing technologist with 20 years of experience in cloud, enterprise software, and DevOps. His diverse background derives from countless successes at HPE, IBM, T-Mobile, and more. He holds a degree in Management Information Systems and is a certified Scrum Product Owner, Scrum Master, PMP, and Pragmatic Marketing practitioner. He is also an international speaker, trainer, and blogger. At OpenText, Michael drives the development and execution of go-to-market strategies for OpenText DevOps and VSM solutions.
The agile testing manifesto: best practices you can’t ignore
Testing in agile isn’t just a step; it’s a core philosophy. If you’re still seeing testing as an afterthought, you’re missing the point. Agile testing…
August 13, 2025
Robust test management: An absolute must for software quality management
Still think testing is just a last-minute scramble? Think again. Robust test management is the bedrock for high-quality, bug-free software. It’s essential to strategically controlling…
July 16, 2025
Unleash the power of AI in testing at STAREAST 2025
OpenText is proudly sponsoring STAREAST 2025, April 30-May 1, 2025, in Orlando and online. Join us and engage with our experts to learn more about…
April 30, 2025
2 min read
